Chasing this down after installing headers. Decided to replace coils, pressure regulator and injectors. Found a set of six by an Ebay vender for less than one from other sources. Expecting them in a few weeks. I'll let you know how it goes. Ebay description : 6x New Jaguar XJ 1995-1997 Fuel Injectors LNA1520BA / D3165KA 720125-812255 DB7
Parker 7
close
- Join DateAug 2021
- LocationKansas City
Liked:1,305 Times in 1,082 Posts
The injectors for the supercharge AJ16SC are different noted by a color band
This is in a TSB link coming
Back to correct Doc
18-46 (jagrepair.com)
AJ6 4.0L EBC 4430 Green Green D3155KA D3155AA
AJ16 N/A DBC 10423 White Green D3156KA D3156AA
AJ16 S/C DBC 11041 Red Green D3165KA D3165AA
See itme 3 as conflicting information
LNA1520BA - Jaguar Fuel injector | Jaguar Land Rover Classic Parts
Back to correct Doc
Parker 7
close
- Join DateAug 2021
Some have sent the their injectors off to be cleaned
There is a do it yourself process to run pure cleaner through them
Keep in mind the supercharged injectors are different than the normally asperated
Thanks Parker,
Have had my injectors professionally cleaned twice over the last few years but would like to compare them with a brand new one .., the listing on eBay that Jagstuart alludes to are the same one I have been eying for some time. Good price! can actually buy a set for the price of one.
I might have an lazy injector or two at low pulse width when idling in Park.
Idle in Drive much smoother.
A injector specialist told me that: Injectors with high flows are hard to control at idle rpms. They deliver so much fuel, it is difficult for the ECU and the mechanical injector to get a low enough pulse width to get consistently delivered equal length open/close times. Such is the nature of a high HP engine. Make its best performance at the higher rpms, and let the idle be what it is.
The XJR's injector flow rate are almost double that of the Xj's.
Also, the early XJR's had problems with excessive carbon buildup around the exhaust valves (Service Bulletin 03.1-10 / Vin720001 - 792388) especially when driven mostly around town and or short trips .., which then could lead to rough idle - highway driving however could then cause the condition to clear up significantly as carbon deposits are then removed.
"Carbon Cutter" exhaust valves (90 degree angle at leading edge) were then introduced after Vin 792388 and could also be installed in affected engines ..,
