so a few days back on my US 1997 xj6L the AC stopped cooling, i tought it was gas cause the car had been parked for over 6 months. but today i took it to AC garage and they told me it was full of gas but the compressor wasnt turning on. so i told them to not do anything that this is something i can prolly fix myself if its electrical.
just want to know if there is a common cause for the AC compressor to not turn on so i can start looking there.
Check fuses.Originally Posted by avioni
so a few days back on my US 1997 xj6L the AC stopped cooling, i tought it was gas cause the car had been parked for over 6 months. but today i took it to AC garage and they told me it was full of gas but the compressor wasnt turning on. so i told them to not do anything that this is something i can prolly fix myself if its electrical. just want to know if there is a common cause for the AC compressor to not turn on so i can start looking there.
Check wiring to compressor and clutch
Does clutch engage?
Check trinary switch
Run a/c module self test sequences
mgb4tim
close
- Join DateApr 2012
- LocationPittsburgh, PA
Liked:92 Times in 75 Posts
Does clutch engage?
Originally Posted by caldercay
Check fuses.Check wiring to compressor and clutch
Does clutch engage?
I have the same issues with my 1995. Which fuses (of the never-ending collection of fuse panels) do I check?
The clutch is not engaging. I think it is one of the electrical connections. There is one on the compressor that is similar to a fuel injection connector. I've popped it on and off a couple times the compressor clutch doesn't engage.
I have a test noid light for fuel injectors, I wonder if the same test light would work with that connector.
Are there any other connectors near the compressor that we just can't easily notice?
sparkenzap
close
- Join DateNov 2007
- Locationatlanta ga
Liked:1,068 Times in 870 Posts
The most likely reason for the clutch to not engage is low refrigerant pressure. Test by jumping the sensor.
mgb4tim
close
- Join DateApr 2012
Quote:
Where is the sensor?Originally Posted by sparkenzap
ahh traced the problem to another corroded connection but this time it was a harness connector near the AC compressor a big one was corroded and had a broken leg so had to do a jumper and AC working again.
on this connector.
on this connector.
