Any body know these Part numbers
I need to find the part numbers of the missing parts in the 2 pictures.
If anyone knows the part numbers and where to purchase these I would be apreciated https://cimg8.ibsrv.net/gimg/www.jag...e13c04b4e8.jpg https://cimg1.ibsrv.net/gimg/www.jag...a957fa193a.jpg Regards Ian |
As for the bulbs and holders, the part number is JLM1928. The can be acquired from SNG Barratt, one of the forum sponsors for about 5 quid:
https://www.sngbarratt.com/UK/#!/Eng...9-34b5969fb40e If your photo shows what I think it's showing, the part number is AGU2643: https://www.sngbarratt.com/English/#...rnedDown=false |
Thanks NBCat. Once I had the numbers I found them local in North America.
Hello. Can you tell me where you got the JLM 1928 or equivalent, please?
Hi.
I got these from Ebay (eBay item number:223657838464). https://cimg9.ibsrv.net/gimg/www.jag...ca37393994.jpg They did not fit as tight as I would have liked, so I removed the bulbs from the black plastic holder, and soldered them directly on to the board. Works perfectly. Ian |
G’day Guys,
For the little instrument and switch lights I re-bulbed mine with small bulbs. There are a couple of types called ‘grain of wheat’ or ‘grain of rice’. They are two different sizes and are a bare bulb with two wires attached. Google them, they were quite cheap and you buy them in small lots of ten I recall. You can use your original bulb sockets, which is a plus. Cheers, Jeff. |
Our member Lawrence just posted this link in the XJ40 forum. They look like correct replacements for JLM1928:
https://www.speedometerbulbs.com/col...ies-brown-bulb P.S. I think NBCat is right about those quarter-turn nuts. Cheers, Don |
Originally Posted by Don B
(Post 2204983)
https://www.speedometerbulbs.com/col...ies-brown-bulb Cheers, Don |
Originally Posted by watto700
(Post 2204971)
https://www.bulbtown.com/2162_Miniat...ase_p/2162.htm https://www.bulbtown.com/2182_Miniat...ase_p/2182.htm https://www.bulbtown.com/1783_Miniat...se_p/b1783.htm |
