Cooling fan 95 XJ6
I just noticed that the cooling fan starts as soon as turn the ignition is on. This does not make sense, is it a problem?
RJ___________ 95 XJ6 120K mi 97 XK8 86K mi |
Not a problem at all, TSB 1/96 No 14-06 covers this issue. Fans were modified to come on with ignition. Not an ideal fix as you certainly don't need them running straight off on a chilly morning.
A more sophisticated fix is to install a relay & have them only coming on with ignition if A/C is switched on. Many owners probably have the A/C on at all times (never switched off) so Jaguars easy fix is probably OK. The only come on on low speed & are then controlled by the temperature thermo switch & the pressure switch on the A/C circuit. The above TSB explains it all. |
