Got hit by loose metal off semi-truck
4 Attachment(s)
On my way home from dropping my stepson off at a local airport I was in the left lane behind another vehicle and both of us were passing a semi-truck. Suddenly a huge piece of loose metal comes flying back, the vehicle in front of me runs it over and it flips up and hits my 1997 XJ6 which I had almost all of the reconditioning jobs finished so I can start enjoying the car. Now I have a bunch more work to do and parts expense.
So at the next exit I pulled over and got out to look at the car. The front edge of the fender, the right hand headlight assembly are all toast. Plus there is a dent in the passenger's door. See the attached photos |
Pretty bad luck.
I have had several broken headlights from stones (about NZD$200 secondhand, and left kidney price new), and broken plastic strip in lower grill from a rock. These plastic strips are not available in NZ secondhand.. But I haven't had bent metal like you. |
Ouch !
On my X300 I had to replace several headlights over the years. They're susceptible to being hit with debris. Cheers DD |
I have two complete headlight assemblies from my ;96 Vanden Plas.
If you're interested in one or both for your repair let me know. Roger |
Bad news but, looking at the level of damage, lucky it didn't hit the windscreen instead of the side of the vehicle.
Graham |
Found fender
1 Attachment(s)
I found a replacement fender at a wrecking yard in Pittsburgh PA. In the attached photo the color appears much lighter than it really is in real life. It turns out the color is a pretty close match for the color of my car. The cost was $60 plus tax but I had to drive down into downtown Pittsburgh to pick it up which was around 1.5 - 2.0 hours each way.
