Help - coolant level sensor dropped out!
Time for a dumb question - do I need to worry about my coolant sensor which has dropped out of the bottom of the expansion tank? i have just changed my XJR Rubber hose from MAF to alloy casting, then went for a short run. The coolant light was on, so I looked and the sensor has dropped out - I must have bumped it when wrestling the new rubber hose into place. There is no leak - seemingly it doesn’t actually sit in the coolant? Do do I need to worry? thanks for any replies |
No cause for concern. It won't leak.
It just sits in a recess in the tank. Put it back in and if necessary secure with some appropriate adhesive or sealant. |
Just plug it back in and it will be fine, unless it is deformed or broken.
