I'm getting hints that the fans run in 2 different manors maybe related to the 2 different relay modules ( white in color ) part #s ( the black X308 relay module runs a close but different circuit on the V - 8 out of the engine ECU that senses the coolant temp by a sensor and not thermoswitches on the X300 )
Both low or both high speed ( from reading others and Motorcarman )
Or mine / one high ( left ) or both high
I have a couple of white fan relay modules around and maybe both white versions
I have my original cut open as water got inside fusing the contacts ( previous owner had it mounted upside-down letting water to get in , you could shake it and hear water )
I once tried to decipher the bowl of spaghetti inside the relay module
The fans and relay module test is quick and easy
Paper clip in the radiator 3 wire coolant temp switch connector
Jump from one white wire to the black ground / one mode
Jump from the other white wire to the black ground / the other mode
Maybe the difference is if you have both white wires jumped to black ground ( both 86 and 100 C temperature contacts ) which I never tried ?
I think you are correct.
Looking at the wiring diagrams the fans operate is series (low speed) at lower temperature and in parallel (high speed) at higher temperature.
