Speedo and Odometer not working
Subscribe
Sep 21, 2020 | 12:10 PM
Hi there,
The Speedo and Odometer are not working on my 95 XJR. The needle moves when the ignition is turned on but then nothing from there. I have already changed my passenger side rear abs sensor but still nothing.
Any help would be much appreciated!
Thanks in advance.
Reply 0
Sep 22, 2020 | 04:58 AM
Are your ABS and TRAC FAIL warning lights on? If it is a sensor issue, they should be, as the passenger side rear sensor feeds them as well as the speedo.
If they are not on, check the wiring between the ABS module and the speedo. Parker2 posted some very helpful diagrams and explanations recently.
Reply 0
Subscribe
Currently Active Users (1)
