Tremendous tank pressure
Old Jun 10, 2015 | 12:10 PM
prestone08's Avatar
Default Tremendous tank pressure
Hey guys,
so I went to fill up the jag after it sitting for a month and When I took the cap off the tank there was TONS of pressure pushing out not sucking in.
(see video Below)
https://www.youtube.com/watch?v=0YVw...ature=youtu.be
I have already replaced this tank rochester valve
Amazon.com: ACDelco 214-552 GM Original Equipment Vapor Canister Purge Valve: Automotive Amazon.com: ACDelco 214-552 GM Original Equipment Vapor Canister Purge Valve: Automotive
What gives? any thoughts?
Old Jun 10, 2015 | 02:55 PM
mgb4tim's Avatar
https://www.jaguarforums.com/forum/x...m-work-114102/
Old Jun 11, 2015 | 05:25 AM
OWRltd's Avatar
Although the GM parts fits and works well as a replacement, did you notice that the arrow on the valve points in the opposite direction? Valve must be turned around from the OE installation. A slightly longer hose is needed to facilitate this.
Poet
Feb 7, 2025 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
vwbusbits
Oct 13, 2015 03:43 AM
moff1959
Sep 26, 2015 05:35 PM
reb1999
Sep 25, 2015 10:00 AM
