Unlock ECU x300 (1996)
Old Apr 21, 2018 | 03:27 PM
gillissen's Avatar
Default Unlock ECU x300 (1996)
Anybody knows how to unlock ECU x300 (Jaguar AJ16 Sagem Lucas GEMS-6 ECU) LNB1410xx
Old Apr 21, 2018 | 03:59 PM
Lady Penelope's Avatar
If you find out let me know .
I want to play .
http://www.gomog.com/allmorgan/GEMS/GEMSbyPoole.pdf
http://www.rangerovers.net/forum/7-r...ifferents.html
Old Apr 21, 2018 | 05:19 PM
This is a link covering immobilization issue and the pin from the SLCU to the ECU is Red 35 . I would think it would be a digital enabling code to reverse the immobilizer but then it could be as simple as adding a ground or DC voltage discrete .
https://www.jaguarforums.com/forum/x...ng-off-196018/
Old Apr 22, 2018 | 11:47 AM
Jagboi64's Avatar
What do you mean by unlock? There isn't a lock per se on the ECU. IF you want to change a parameter, those are all hard encoded on a chip, so you'd need a chip burner and the software ( and knowledge!) to do that.
If you so want to change the programming, send a message to XJR Engineer on here. He helped develop the code originally for Jaguar.
Old Apr 22, 2018 | 11:50 AM
Jagboi64's Avatar
The fuel inhibit is encoded communication between the ECU and security module. However, North American spec cars don't use it.
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
vmaxie
Jan 17, 2017 01:09 PM
GabrielG
Dec 2, 2016 09:00 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
JimC64
Apr 16, 2015 08:20 PM
