What is a "Intake Manifold Runner Control"???
Old Apr 14, 2010 | 09:37 AM
TOMALONIC's Avatar
Default What is a "Intake Manifold Runner Control"???
P1516 -Intake Manifold Runner Control Input Error (Bank 1)
This is the error code P1516 that pops up when my 97 VDP stalls after slowing down rapidly. It appears that the engine slows down soo much that the engine stalls. Any advice for me?
Old Nov 19, 2021 | 09:52 PM
jag.to's Avatar
Default Same issue!!
We’re there any solutions?
Old Nov 19, 2021 | 11:01 PM
Parker 7's Avatar
The inlet air control valve should sequence down after a throttle let off to eventually bring the idle speed down to target
There should also be some gradual changes to the amount of fuel charged into the cylinders ( pulse width )
You can test with a meter if you have a bad leg or winding in the IAC step motor
You can try a tank fill injector cleaner to unstick a dragging fuel injector before you take the step of removing them for cleaning ( under fueling )
Does the butterfly return to the idle closed stop without your hand aiding it ?
Old Nov 19, 2021 | 11:24 PM
Parker 7's Avatar
see page 131
801S TITLE (jagrepair.com)
Syb Drylst
Jun 12, 2020 04:41 PM
felinecat
Mark V - X 420G
Jul 14, 2017 11:35 PM
harvey_birdman
Jun 30, 2013 12:56 AM
stevis05
Feb 17, 2009 05:30 PM
rianbechtold
Nov 28, 2008 08:51 AM
