2003 XJ8 Transmission Fluid & Filter R&I
3 Attachment(s)
Hi
I am posting this new thread because I could not find another thread with instructions & illustrations that covered 2003 XJ8 Transmission Drain/Fill and the R&I for the Transmission Pan and Filter. Here are 3 PDF files I extracted from the JTIS Repair CD: Attachment 13241 Attachment 13242 Attachment 13243 There maybe a couple of other threads describing how to do the Drain & Fill without using the PDU device. I will try to find and include them at a later date. Jim Lombardi |
Hi
I found another thread with this information and more that I created for 2001 XJ8 (5/20/2001) - https://www.jaguarforums.com/forum/x...-cd-faq-54942/ It is also listed in the FAQ sticky Thread - use the Internet Explorer (Edit then - Find on this Page) to search for ZF5HP24 in FAQ sticky Thread. Jim Lombardi |
Hi
I found a post that forum member "test point" (Tom) describes a way to fill the fluid to capacity without using the PDU device (See post# 6): https://www.jaguarforums.com/forum/x...ns-help-36256/ Jim Lombardi |
Thanks jim, FAQ'ed
Someone awhile back was selling (and maybe still is selling) a transmission dipstick unit to install on these cars. Would that eliminate all the rigamarole that the factor procedure requires?
