2003 XJ8 Transmission Fluid & Filter R&I
Old Oct 1, 2011 | 09:37 PM
jimlombardi's Avatar
Default 2003 XJ8 Transmission Fluid & Filter R&I
Hi
I am posting this new thread because I could not find another thread with instructions & illustrations that covered 2003 XJ8 Transmission Drain/Fill and the R&I for the Transmission Pan and Filter.
Here are 3 PDF files I extracted from the JTIS Repair CD:
2003 XJ8 Transmission Fluid Drain & Fill.pdf
2003 XJ8 Transmission Fluid Pan R&I.pdf
2003 XJ8 Transmission Fluid Filter R&I.pdf
There maybe a couple of other threads describing how to do the Drain & Fill without using the PDU device. I will try to find and include them at a later date.
Jim Lombardi
Old Oct 1, 2011 | 09:49 PM
Hi
I found another thread with this information and more that I created for 2001 XJ8 (5/20/2001) -
https://www.jaguarforums.com/forum/x...-cd-faq-54942/
It is also listed in the FAQ sticky Thread - use the Internet Explorer (Edit then - Find on this Page) to search for ZF5HP24 in FAQ sticky Thread.
Jim Lombardi
Old Oct 1, 2011 | 10:18 PM
Hi
I found a post that forum member "test point" (Tom) describes a way to fill the fluid to capacity without using the PDU device (See post# 6):
https://www.jaguarforums.com/forum/x...ns-help-36256/
Jim Lombardi
Old Oct 2, 2011 | 04:04 AM
Cadillac's Avatar
Thanks jim, FAQ'ed
Old Oct 2, 2011 | 11:57 AM
Boomer from Boston's Avatar
Someone awhile back was selling (and maybe still is selling) a transmission dipstick unit to install on these cars. Would that eliminate all the rigamarole that the factor procedure requires?
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
OkieTim
Sep 8, 2015 04:48 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
pnwrs2000
Sep 3, 2015 11:55 AM
