2nd Broken Headlight in Last Two Weeks ?
I have shattered two headlights separately over the last two weeks, both I believe were probably originals by appearance but no way of knowing for sure as second owner. First was left outside and second was right inside, never heard or felt a bang or saw a rock coming or anything, just come out in the morning to find broken, no glass around except for inside of bucket. I have another off eBay on the way but was wondering if you guys could enlighten me on what's going on here, could they become fragile with age, improperly mounted, or something else ?
You didn't tic off a neighbor by chasing his daughter? ...lol :eek: :icon_omg:
Sounds like bad luck in any case. |
Actually, we did piss off the neighbors behind us after my other neighbor caught their teenage son on security cam trying to break into his car. Then I complained about his taking the side boards off my trailer and making a bridge across the creek that separates us. But none the less I don't think anyone has deliberately been busting my headlights, no glass to be found on the ground, only inside the bucket, so I guess for now I will just chalk it up to bad luck and hope it improves :-)
Make sure they are tight & fully pressed in.
I'm going to do that first thing tomorrow morning, good advice and thanks :-)
Originally Posted by astark
(Post 2041379)
I think you found my answer Charles, upon inspection the broken and not yet replaced has the play you described as well as another, the other two are good and tight. I will be investigating further tomorrow and thanks again :-)
(Post 2041888)
I found a broken headlight adjusting screw, the ball on the end that snaps into the headlight has broken off allowing it to flop up and down enough to cause breakage. Not sure I'm calling this adjustment screw by the correct name but I can't seem to find a replacement, got any ideas ?
Local wrecking yard?
Originally Posted by Highhorse
(Post 2043086)
I believe that's it !! but just need the screw with ball on end and not the whole kit. May only find in kit form but that was another great help, thanks again :-)
(Post 2043119)
Got the adjuster kit from eBay on the way, should be here Monday afternoon :-)
