2nd Broken Headlight in Last Two Weeks ?
Old Mar 17, 2019 | 08:16 AM
astark's Avatar
Default 2nd Broken Headlight in Last Two Weeks ?
I have shattered two headlights separately over the last two weeks, both I believe were probably originals by appearance but no way of knowing for sure as second owner. First was left outside and second was right inside, never heard or felt a bang or saw a rock coming or anything, just come out in the morning to find broken, no glass around except for inside of bucket. I have another off eBay on the way but was wondering if you guys could enlighten me on what's going on here, could they become fragile with age, improperly mounted, or something else ?
Old Mar 17, 2019 | 07:44 PM
Highhorse's Avatar
You didn't tic off a neighbor by chasing his daughter? ...lol
Sounds like bad luck in any case.
Old Mar 17, 2019 | 08:55 PM
astark's Avatar
Actually, we did **** off the neighbors behind us after my other neighbor caught their teenage son on security cam trying to break into his car. Then I complained about his taking the side boards off my trailer and making a bridge across the creek that separates us. But none the less I don't think anyone has deliberately been busting my headlights, no glass to be found on the ground, only inside the bucket, so I guess for now I will just chalk it up to bad luck and hope it improves :-)
Old Mar 17, 2019 | 08:57 PM
King Charles's Avatar
Make sure they are tight & fully pressed in.
Old Mar 17, 2019 | 10:14 PM
astark's Avatar
I'm going to do that first thing tomorrow morning, good advice and thanks :-)
Old Mar 17, 2019 | 10:34 PM
Yeah despite the adjuster fittings looking correct I've had to actually press mine back in & it yielded about a half inch of play corrected.
Old Mar 18, 2019 | 08:48 PM
astark's Avatar
I think you found my answer Charles, upon inspection the broken and not yet replaced has the play you described as well as another, the other two are good and tight. I will be investigating further tomorrow and thanks again :-)
Old Mar 18, 2019 | 11:26 PM
No problem, I went through an ordeal chasing down random noises up front & found mine.
Old Mar 20, 2019 | 09:11 PM
astark's Avatar
I found a broken headlight adjusting screw, the ball on the end that snaps into the headlight has broken off allowing it to flop up and down enough to cause breakage. Not sure I'm calling this adjustment screw by the correct name but I can't seem to find a replacement, got any ideas ?
Old Mar 20, 2019 | 09:16 PM
Highhorse's Avatar
Local wrecking yard?
Old Mar 20, 2019 | 09:38 PM
astark's Avatar
Maybe, but not likely around where I live, surprised I cant find any on eBay.
Old Mar 20, 2019 | 09:52 PM
This what you're after ?!
Part : JLM12118
https://www.sngbarratt.com/us/#!/Eng...0Series%20X308
Old Mar 20, 2019 | 10:16 PM
astark's Avatar
I believe that's it !! but just need the screw with ball on end and not the whole kit. May only find in kit form but that was another great help, thanks again :-)
Old Mar 21, 2019 | 12:34 AM
They're on eBay used just search the part #. Good luck !
Old Mar 21, 2019 | 09:13 AM
astark's Avatar
Got the adjuster kit from eBay on the way, should be here Monday afternoon :-)
uclabrruin1989
Oct 13, 2018 10:12 PM
XJsc-guy
Jan 7, 2016 11:13 AM
hdsg
Jun 7, 2013 07:32 PM
Jackuar
Jun 6, 2012 10:28 AM
brgjag
Feb 11, 2010 07:35 PM
