Broken headlamp
I have a broken glass lense on my 02 xj8 vanden plas Do I have to change entire lamp assembly or just the glass?? Looks complicated getting it taken apart, has anyone done it? Thanks Steve
Steve,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help. Graham |
Originally Posted by bumpasjag
(Post 1008799)
To get at them first remove the colour coded plastic surround which will expose the light unit mountings. You will see there are three ball ended mounts on the frame. spary silicon or similar onto these and either using two wide flat pieces of wood or plastic, lever the light unit off it's mountings....or, you can grasp it with both hands and pull forwards. To replace make sure the plastic ball sockest are not broken...they get brittle with age and heat....dab a little greae or petroleum jelly on the ball ends,line up the light unit in the correct orientation and firmly push into place...check light alignment afterwards. |
