cant get into learn mode for new fob - SOLVED
I've tried following all the instructions but can not get the car to beep. What am i doing wrong?
Drivers door open Pull high beam lever and hold Put key in and turn to position 1 Release high beam lever and toggle it 4-5 more times |
Does the factory stereo have anything to do with this system because I replaced mine?
Problem solved.......kinda. My alarm chirp horn is broken/disabled. In the dark I can see the gear select light come on. I still can't get the switchblade key fob to connect but thats another subject.
By any chance, does someone know where the alarm chirp horn is located? :D |
