ChristmasGT's 2001 Jaguar XJR Owners Thread
Hello everyone!
I'm a first time Jaguar owner, but a long time Mustang tinkerer and have decided to pull the trigger after a bit of looking on an 2001 Jaguar XJR that I've wanted for some time The car has 188k miles on it, and is in remarkably good shape for the age and mileage. It had been sitting outside for about 2 years, and was last running in 2021 from what I was told. Once home, I decided to give it a bath and a new battery and it cleaned up pretty good! I'm not sure of the timing chain guides, but it looks like the valve covers have been off from what I can see as they have a bit of Orange RTV over them.
Overall, I'm not planning to mod the Jaguar in any capacity, I think the car looks perfect as is. The goal on this thread will be OEM style replacement and maintenance where able, hopefully I'll be able to document most of my work in this thread as I move along with it. Link to car Images on Imgur: https://imgur.com/a/1egHuuA |
Welcome. I've had a few old Mustangs myself. These cars are notorious for having the fuel pumps seize up from sitting unused even for a relatively short time. Don't know why they'd be any worse than other cars, but I've read enough posts about it here that seems to be the case.
With the key on engine off, there should be two things making noise under the hood.
1) The throttle body makes a humming noise and when you depress the accelerator pedal, the pitch in noise changes. 2) The auxiliary electric water pump for the supercharger below the air filter box may make a small amount of noise. I can’t comment if you really need the stock fuel pump wiring harnesses or not because I’ve always just reused them. When you go to replace your pumps, **do not** just pull the tank back without disconnecting both of the fuel lines from underneath the car first! |
Originally Posted by Addicted2boost
(Post 2691052)
1) The throttle body makes a humming noise and when you depress the accelerator pedal, the pitch in noise changes. 2) The auxiliary electric water pump for the supercharger below the air filter box may make a small amount of noise. I can’t comment if you really need the stock fuel pump wiring harnesses or not because I’ve always just reused them. When you go to replace your pumps, **do not** just pull the tank back without disconnecting both of the fuel lines from underneath the car first! I'll document the process as I go through it, hopefully this will bring her back to life. |
Both Fuel pumps replaced, and now she runs! The Electronics I tested seem to work well with things such as the Stereo, Moon Roof, Fan and Windows being alright. The Transmission seems to shift just fine while doing a quick drive around the block. Being under the car for the last few days, it appears the car has no rust, so it has a great base.
Unfortunately that's about where the good ends, I'm 99% sure the car has a head gasket problem. The car starts right up, but starts billowing quite a lot of white smoke which tells me coolant is entering the cylinders. The smoke persists the entire time the car is running and is definitely quite a lot. This probably explains the Misfire Detection that the ECU is reporting (2, 4, 5, 6). From here, I need to determine the future of this car:
Thoughts? http://i.imgur.com/mnuGz4pm.jpg http://i.imgur.com/ebmrkRzm.jpg http://i.imgur.com/BSntg9Lm.jpg http://i.imgur.com/YZtbMwcm.jpg http://i.imgur.com/9AwWaWBm.jpg http://i.imgur.com/EtAjIgFm.png |
I opted for the Walboro 340’s which is overkill but, they’ve been reliable in the GN so I carried it on.
As long as it doesn’t appear to have much sludge build up with the miles it has, no milkshakes and a debris free oil pickup screen, I’d be completely comfortable with doing head gaskets on it. I will highly recommend sending the heads to a machine shop to check for cracks, milling the gasket surface, complete valve job, valve adjustment with new stem seals and if all else is fine, it should pull quite strong. When I acquired my 98’ XJR in 2014, it had 234k miles on it. I bought it knowing I was going to pull the heads. After the heads were gone through and the engine ran, that car pulled hard. It now belongs to my daughter and it has 280k miles on it still running strong. |
At this age, yes, it needs a whole lot of maintenance. But if you do an LS swap, that doesn't relieve you of having to all of it, rather, all the suspension stuff would still need replaced plus if you were to get a used LS that's like 10 years old then you really need to replace all that same sort of stuff on the LS motor while its easily accessible. Its either that, or spend a whole lot more money on a crate engine and all new ancilliaries. At least pull the old motor apart and inspect it. If the repair itself is inexpensive, i.e. just headgaskets, then its probably worth doing all of the deferred maintenance.
Hey Guys,
I'm trying to go down the route of seeing what's all wrong with the engine. When idling, it seems to sound like there's a large vacuum leak near the drivers side area under the super charger. Right now it idles pretty rough, and I'm assuming it's due to the leak. Here are a few videos showing what it sounds like at the moment: I checked the breather valve on the driver side of the valve cover gasket, and it doesn't appear to be coming from there. Any general things in that area that may cause it? EDIT: Added a third video to try without the super charger pulley and resulted in the same sound. When turning the pulley by hand, I definitely hear the sound in the area which I'm assuming I shouldn't. Perhaps the super charger gasket failed? |
There’s a few ways to diagnose this. A mechanics stethoscope, hold a flexible hose to your ear and use the other end to move it around the engine to see where it’s loudest, a can of brake cleaner and flashlight to *gently* spray a small amount around gasket and vacuum hose areas until the engine revs up.
The supercharger in my 2000 XJR makes that same diesel-like rattle, but I don't have that whooshing sound at all. When I pull the engine for the LS swap, I'm going to investigate to see what's wrong with it, mostly out of curiosity...:icon_wink:
Get a Stinger smoke tester, one of the best tools you will ever buy - that will show the leak, and it does sound like there is one.
Originally Posted by 57loboy
(Post 2692532)
Hey guys,
Sorry for the delay here. Since the $1000 dollar jag turned into a bit more than a fuel pump problem, I wanted to finish my 1984 Mustang 2.3 Turbo GT and get it road worthy before I dig in to the Jaguar any deeper. The good news is that it should be wrapped up by Tuesday once my new Brake Line arrives. In the meantime, I'm going to be doing some additional diagnostics on the Jag to see what's going on. Ultimately, I've decided that I'll try and repair the 4.0 and replace the head gaskets and all things timing related as well as seals. During the process, I'll send the heads off to get re-done, though if I find out the pistons / valves are bent then I'll probably attempt an LS swap at that point (signs seem to point to no?). The good news is that the smoke has subsided significantly, and may have just been a symptom from sitting for so long.
(Post 2692648)
If the supercharger looks like someone has been in it before, there’s a good chance that a solid coupler has been installed in place of the factory Eaton spring loaded coupler. You could simply remove the supercharger belt and start the engine. If the rattling noise is gone, Bobs your uncle. If the noise is still there, then look at the timing chains.
Originally Posted by Hell-Cat
(Post 2692587)
Before you do the head gasket remove the thermostat and add 1 bottle of sodium silicate head gasket sealer
I had luck with land Rover lr3 years later still working fine |
Hey Mobile1,
Went through the smoke test and it looks like there's a huge seal leak at the valve cover gasket. That would explain why I wasn't getting much of a response from the carb cleaner. On the good side, it appears someone must've known because I found a brand new OEM Gasket in the rear seat. Will change that today which should give me a good glimpse on the timing chain tensioners as well. Also, I had major smoke leaks from after the MAF on the intake side, so will need to add that to the list as well. |
Originally Posted by ChristmasGT
(Post 2692742)
Hey Mobile1,
Went through the smoke test and it looks like there's a huge seal leak at the valve cover gasket. That would explain why I wasn't getting much of a response from the carb cleaner. On the good side, it appears someone must've known because I found a brand new OEM Gasket in the rear seat. Will change that today which should give me a good glimpse on the timing chain tensioners as well. Also, I had major smoke leaks from after the MAF on the intake side, so will need to add that to the list as well. https://youtu.be/pi08pTJUJ08 CHAINS / TENSIONERS / GUIDES EAZ1286 Timing Chain Primary x 2 EAZ1269 Timing Chain Secondary x 2 AJ82325 Tensioner Primary x 2 C2Z2642 Tensioner Primary Bolts x 4 C2A1511 Tensioner Secondary Left C2A1512 Tensioner Secondary Right JFB10607B Tensioner Secondary bolts x 4 NCA1998AB Chain Guide x 2 NCA2025AB Chain Guide x 2 VALVE COVER GASKETS AJ88285 Cam Valve Cover Gasket Left AJ88400 Cam Valve Cover Gasket Right AJ87206 Spark Plug Tube Seal Inner x 8 AJ87242 Spark Plug Seal Center x 4 NCA2575CA Camshaft Cover Grommet x 28 AJ82856 Valve Cover VVT O-Ring x 2 BUSH CARRIER GASKETS NNE2622BA O-Ring VVT Bush Carrier (2 Each Side) x 4 KSH108624 O-Ring Bush Carrier x 2 CRANKSHAFT SEAL / TIMING COVER SEALS AJ83698 Front Crank Seal AJ89909 Front Crankshaft Bolt AJ89854 Front Crankshaft Split Cone (Collet-Split) XR81139 Front CrankShaft O-Ring AJ83700 Timing Cover Gasket - Outer AJ83699 Timing Cover Gasket - Inner KSC145624 Timing Cover O-Ring x 2 OIL PAN SEALS / FILTER NCA1730AD Lower Oil Pan Gasket EAZ1354 Oil Filter MISCELLANEOUS Loctite Ultra Gray 5699 RTV |
Hey guys,
Valve cover is off! Looks like the tensioners have already been replaced. The chain has no play at all. In the second pic, the leak was in the top left portion of the second picture below. Going to pick up a new Felpro set (VS50724R) as it looks like I'll need to replace all of the O-Rings. I'm also going to replace the coil packs and plugs too. Will update later (hopefully today?) on progress. https://i.imgur.com/x3uFs7Gl.jpg https://i.imgur.com/ZORRQhTl.jpg https://i.imgur.com/uTYgLgml.jpg |
In the second picture, I’m fairly confident that is an original tensioner. I can’t quite tell due to the glare of the light. If you took another picture of the top photo with flash on, that would be helpful.
Actually, looking at it in comparison with the new style, it appears you're absolutely correct. It has to have been replaced before I'd think as there' a bit of RTV around each corner, and the chain feels super tight. Looks like I might as well order a new kit at this point as well as the cam lock kit.
Would this work? |
(Post 2692794)
Would this work? This is the narrow chain guide its for later model Get the wide guides much better get from ebay this is genuine ford part https://cimg7.ibsrv.net/gimg/www.jag...1af8fd8a70.jpg |
