Driver's door latch
Old Apr 11, 2014 | 09:45 PM
obriendob's Avatar
Default Driver's door latch
Hi
I need some help
The lock mechanism and interior door cable broke on drivers side within a week of each other
I bought a cable from Welch and a used lock actuator on EBay
I replaced both
The door now opens from the inside and the door locks
But
The door does not open from outside
The handle protrudes slightly and will not open latch
Suggestions welcome
Old Apr 11, 2014 | 10:47 PM
ragman1171's Avatar
I'm probably not going to be too much help, if any, but you said you replaced the interior door latch cable and the lock actuator.
I would start with checking the connection between the exterior latch cable end to see if it was knocked out of place. If it's disconnected, then that wold explain why the door won't open and if it's disconnected and then the space noramally taken up by the connection to the latch is not extended and would give the outer handle a bit more cable and that could explain why the handle protrudes slightly.
The outer door handle cable end may be out of place or broken off now too...
I've never had the doors apart on a Jag, but have on domestics. I'm just spit-balling and trying to help. Maybe if you go through what I just recommended, the actual culprit will reveal itself. Keep us posted!
Old Apr 12, 2014 | 08:12 PM
obriendob's Avatar
Thanks for the feedback
Based on your advice I backtracked my steps
The exterior door latch cable hooks to the actuator
This cable is is plastic piece that screws on to the cable
In simple terms, the adjustment was off, too strong - I disconnected the actuator - lined everything up - and then reconnected
Everything works as it should
Now- if I fixing that rear rattle I've been chasing for 4 years was that easy......
Old Apr 12, 2014 | 08:33 PM
ragman1171's Avatar
Glad to hear you found it. I had no adjustable! The rattle is rough... lol... have someone else drive on a bumpy road and see if its something that fell down in between some of the springs or under one of those seats latch covers or something to that effect. A penny under the seat bolt cover will rattle and you will never see it. Again, I have never taken the seeds out of a Jaguar. But, its just a thought. Best of luck.
Old Apr 13, 2014 | 03:15 PM
Jhartz's Avatar
"Now- if I fixing that rear rattle I've been chasing for 4 years was that easy......"
Rattles drive me nuts, too. If it is not the lower rear shock mounts (cost $350 to install new shocks and mounts to prove that weren't it), try some silicon grease on the rubber grommets that holds the mufflers at the rear of the car. Every couple of weeks you will find me on my back lubing the damn things, but silence is golden.
The crappy upper brake light also rattles . . . but so do both shoulder and knee joints (age matters!).
Now, if this was a Range Rover Sport, I could tell you about twenty different rattle points . . .
Old Apr 13, 2014 | 03:31 PM
andrew lowe's Avatar
"All annoying squeaks, knocks and rattles can easily be silenced very cheaply by the volume knob on the radio"
If I remember correctly, that was rule number 4 on how to treat company cars that was on the workshop wall.
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
TexasCat
Sep 8, 2015 04:36 AM
Jay48
Sep 7, 2015 09:30 PM
philwarner
Sep 3, 2015 10:14 PM
