Engine light-OBD II no vehicle detected
My engine light went on with "check gas cap" in the message center.
I opened it and closed it. Engine light is still on. Sooooooooooooo, I came home and fired up my "autotap" and plugged into the OBD port. I get "no vehicle detected" as a message. Connections are good and tight and this works on my lincoln. Any ideas? tia |
No power to the obdii connector, check all your fuses i dont rememebr off the top of my head which one is for the port
