engine removal and rebuild
Old 01-14-2018, 02:21 PM
Belmon's Avatar
Progress
Old 01-14-2018, 02:23 PM
Belmon's Avatar
And as I’m transferring the video footage to my computer and recharging the GoPro time for a quick break
Old 01-14-2018, 02:49 PM
BobRoy's Avatar
Belmon,
I would go a little easy on the sealant this time when you put it back together. When I do my cam cover gaskets the only place I put anything is where the head joins the timing cover and then it is only a dab.
Good luck
Old 01-14-2018, 03:10 PM
Belmon's Avatar
Originally Posted by BobRoy
Belmon,
Good luck
It was like that because of the valve covers constantly leaked and I couldn’t find where it was leaking from so I thought if I rtv the whole thing that it would stop.
But it didn’t. So I think there’s a crack on both of them. So I got new ones.
Old 01-14-2018, 10:06 PM
Belmon's Avatar
Tomorrow the bottom end comes out. Cylinders 1 and 7 when the heads are off I put my palm over to see if there’s any suction I also tried with a old hard cover book and they have no suction I still see the cross hatching on all 8 with no scoring that my finger nail can catch on.
Old 01-15-2018, 03:52 PM
Belmon's Avatar
Had a bit of a heart attack when I thought I rounded a head bolt but it only broke my socket
Old 01-15-2018, 03:55 PM
Belmon's Avatar
Also I found leaking intake valves on the right head
  #28
Old 01-15-2018, 04:08 PM
BobRoy's Avatar
Do the leaky valves match up with your low compression cylinders?
I don't know what kind socket you used to remove the heads but what I did was to use an 13mm impact socket and I ground the outside of it off a little so it would fit in the head bolt hole.
Belmon (01-16-2018)
Old 01-15-2018, 09:48 PM
Belmon's Avatar
BobRoy (01-15-2018)
  #30
Old 01-15-2018, 09:57 PM
Belmon's Avatar
Only one valve matched up to the right side with low compression the left side I’m going to look at more closely tomorrow after work. It’s a good thing I took the engine out and apart some of the rod bearings were starting to spin now. I need to translate the bearing codes to get the colors and de grease the engine and find a place to hot tank the block/main bearing plate/sump/heads. And get a straight edge to check if the head/block it true.
  #31
Old 01-15-2018, 09:58 PM
Belmon's Avatar
I also need to put all of the video footage together for a time lapse video
  #32
Old 01-16-2018, 12:44 AM
Belmon's Avatar
And on the head bolts bob I found that my 13mm was fitting loosely and felt like it wanted to round out the bolt heads so I went to a 1/2” Crome deep socket and it fit a little tighter. That worked for the left head. But it broke on the right one then I got a 12 point 1/2” impact socket for the rest. Also bob what tool do you use to get the valves out. I went to some auto parts store and the ones they rent won’t work for these heads because the valve springs are in there own little pockets.
  #33
Old 01-16-2018, 07:16 AM
BobRoy's Avatar
The one I have is similar to the one in the link. I won't vouch for the quality of this one but the one I have was around $90.
https://www.googleadservices.com/pag...3D%26veh%3Dsem
I use a multi compartment container and put everything from each valve in its own compartment and mark where it came from. I like to put everything back together the exact way it came out.
Be careful of the retainers. They are very small and can be easily lost. Have a clean area for disassembly and assembly. You will probably drop a few and they will be hard to find if it's a cluttered area.
Edit: If you are having a machine shop do your heads let them do the disassembly. On my heads I did it myself since mine only needed to be lapped in but if the seats or valves are bad enough that they need machine work I would let a machine shop do the work.
Belmon (01-16-2018)
  #34
Old 01-16-2018, 08:40 AM
Belmon's Avatar
If the heads and block are true and not warped I just want them to hot tank the block and heads sump, main bearing plates. I’m going to buy a bunch small containers after work. I might just get a a large c-clamp with a large o2 sensor socket to do it.
  #35
Old 01-16-2018, 08:54 AM
BobRoy's Avatar
I don't think that will work. Even with a spring compressor it is difficult to reinstall the retainers. You will have more access to get them in with the spring compressor.
I cleaned my heads with the purple degreaser and a pressure washer. The almost looked new when I was done.
First pic is my Harbor freight container then the before and after on cleaning the heads.
Belmon (01-16-2018)
  #36
Old 01-16-2018, 10:01 AM
Belmon's Avatar
Ok. I ordered that spring compressor. And I’ll go to harbor freight today.
The problem is washing it. They tore down some self car washing places and are rebuilding them. I might just buy a big tub to dip the heads in degreaser. Not sure about the block yet. I’ll look around for a place.
  #37
Old 01-16-2018, 11:18 AM
BobRoy's Avatar
Try the purple power degreaser with a garden hose. Sometimes it might get it clean enough. Once cleaned I use air to dry it then I will put it in a clean garbage bag or whatever to keep it clean until I'm ready to reassemble.
Belmon (01-16-2018)
  #38
Old 01-17-2018, 10:19 PM
Belmon's Avatar
8 hours of footage over 3 days
popeye68 (01-18-2018)
  #39
Old 01-18-2018, 10:28 PM
Belmon's Avatar
ok so i think i got the right bearing colors but i would like someone else to double check my work to be sure
engine numbers sjgkf*baab 22222223*rrnrp
link to engine pdf http://www.jagrepair.com/images/Auto...Code%20168.pdf
pages 54-59
rod bearing color
b/1 green
a/2 blue
a/3 blue
b/4 green
main bearings crank journal diameter
s/1 61.985mm
j/2 61.992mm
g/3 61.994mm
k/4 61.991mm
f/5 61.995mm
main bearing bore inside diameter
r/1 66.018mm
r/2 66.018mm
n/3 66.020mm
r/4 66.018mm
p/5 66.019mm
main bearing color
1 blue/green
2 blue/blue
3 blue/blue
4 blue/blue
5 blue/blue
cylinder bore
2 b1
2 b2
2 b3
2 b4
2 a4
2 a3
2 a2
3 a1
  #40
Old 01-18-2018, 10:46 PM
Belmon's Avatar
also for main bearing #1 blue/green witch one is the top and bottom?
Quick Reply: engine removal and rebuild
