These are the plastic covers on top of the radiator and engine on a 2004 XJ8 Vanden Plas. I lost a couple of fasteners from the radiator cover (picture bottom) and one for the engine cover (picture top). Any idea how/where to buy them? Thanks in advance.
Use this... Car-Part.com--Used Auto Parts Market ...to find yards in your area with your model and give them a call or just roll over and take a look and get'em. Shouldn't cost but a couple bucks vs full tilt new.
Top is one of four fasteners that attach the
Suggest you try this: this is from Auveco in KY. Box of ten is $13.19. I'm not certain if this is your item, but sure looks close. Their part #20518. Hope this solves your problem. I'm using them in my 07 XKR to hold rear of engine cover panels in place. Ford Radiator Sight Shield Retainer 24.5 Hd Dia
Radiator Sight Shield Push-Type Retainer
Black Nylon
Head Diameter: 24.5mm
Stem Length: 14mm
Fits Into 9mm Hole
Replaces Ford: W705957-S300, W706519-S300 Lincoln LS 2000 -
