How do I remove the pinstripe?
I did a quick search but couldn't find anything.
Does anyone have any idea how to do this? My 98 XJR has a pinstripe but to be honest I think it detracts from the lines of the car. It seems painted on and when you run your fingers over it, it is slightly raised. I tested a small area where the line starts inside the door and managed to use my finger nail to flake a tiny bit off. If I do this for the whole car though I won't have any finger nails left by the end of it. Any suggestions? |
You are looking for an eraser wheel. Its a piece of rubber shaped like a wheel that you put on the end of a drill. Any auto body or paint shop will have some.
Removing the pinstripe definitely makes the car more stealthy. |
Originally Posted by covshark
(Post 770098)
Removing the pinstripe definitely makes the car more stealthy. Out of interest what stops the eraser wheel from rubbing through the other paint? |
Originally Posted by Bondy
(Post 770103)
I've read about these. Out of interest what stops the eraser wheel from rubbing through the other paint?
As you're in Reading, you'll want a UK supplier. The online supplier bodyshop247.co.uk stock an 84mm Rubber Eraser Wheel suitable for pinstripe removal. Graham |
Light pressure, constantly moving, not too fast. It really works just like an eraser . . . without damaging the paint. You might want to use a little polish after use but that is all that is required.
The stripes on my car were decals not paint |
The gold pinstripes on my VDP seem to be coming off during a wash. Passenger side is starting at the rear, driver side at the front. It is starting to approach looking a bit haggard.
Perhaps it was once a decal and after 15 years it's gone rock hard. Whatever it is it seems to flake off easily enough.
I'll order myself a rubber wheel and give it a go. Thanks everyone. |
(Post 770539)
Originally Posted by RetardeD2
(Post 2314353)
I know this is a really old thread but how did it go?
I had my pinstripe replace recently, because, well I like them. The left front wing had a ding, so needed a re-spray so I had to figure out what to do.
I bought my X308 in the USA when we lived there. I was told that a lot of Jaguars put striping on themselves. And it seems to be the case with mine. So taking the old striping off, which was just a decal, was done by carefullheating with a hot air gun and a little plastic scraper. It did come off alright, but the paint was ever so slightly blemished. Not a problem in my case as we put new ones on top of it You can read all about it here, need to scroll down a bit: https://www.team-bhp.com/forum/diy-d...ml#post4756635 Jeroen |
| All times are GMT -5. The time now is 11:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
