Need help with hoses and vacuum lines
I'm putting my XJR back together at the moment. Almost 3 years ago it overheated and dropped three valves. I took it apart and removed the heads but then it sat in my garage for almost 2 1/2 years while I decided if it was worth spending the money to rebuild it. I finally decided to rebuild the heads and got them back at the start of this year and have since been slowly putting the car back together as I've had time. We'll I'm getting close to finishing it and I'm at the part where I will be installing the intake elbow and EGR.
Here is my problem, its been almost three years since I took this apart and when disconnecting the vacuum line some of the lines or their connectors were so brittle they just broke, others were actually melted, so I wasn't able to label which line goes to where. The intake elbow and the EGR both have vacuum line coming off them that I don't know where they lead and once I install them on the car I will block off access to some hose connectors below it, so i've to things I need to hook up before I can do install this. Here are a few pics of what lines and hoses I need to figure out where they go. I'm sure there will be others I discover as I go along but this is where I'm at now... https://cimg9.ibsrv.net/gimg/www.jag...1b2ec57c07.jpg This vacuum line on the intake elbow, I think it goes to a "T" connector that broke when I was taking things apart, so I don't know what it T's into and where the other lines of the T go. Also the metal hose connection there, does that go to the EGR? https://cimg4.ibsrv.net/gimg/www.jag...a3a386cc2f.jpg Then there is this line which I think is part of the evap or emissions system. It is a t connector with one elbow shaped molded rubber hose of one of the T, and a broken vacuum line off the other. The line on the bottom of the T leads to this thing on the firewall. https://cimg9.ibsrv.net/gimg/www.jag...9aad05dd8c.jpg This broken vacuum line that goes to the "UFO" looking thing off the passenger side fuel rail. https://cimg1.ibsrv.net/gimg/www.jag...6cceeddfb4.jpg This plastic connector just in front of the driver's side connector on the "octopus hose." https://cimg8.ibsrv.net/gimg/www.jag...bcdb941eba.jpg Finally this hard metal line which goes under the passenger side head. I don't know where the other end of it goes. Any help figuring out where these lines go would be much appreciated. Thanks. |
Can we please get you to put your year and model in your Sig so we're not guessing at it? XJ...XJR 97-03?
This is about the EMS, but it shows the hosing and the second is an overall.... https://cimg2.ibsrv.net/gimg/www.jag...a328326aac.png https://cimg6.ibsrv.net/gimg/www.jag...057c63ae47.gif |
Originally Posted by Highhorse
(Post 2095581)
This is about the EMS, but it shows the hosing and the second is an overall.... https://cimg2.ibsrv.net/gimg/www.jag...a328326aac.png https://cimg6.ibsrv.net/gimg/www.jag...057c63ae47.gif Thanks for the pages, is that from the workshop manual? I'll try to find that in my copy. |
5 Attachment(s)
The hose from the FPR ( the "UFO" looking thing) goes to a port at the right side of the supercharger cover. The port is slightly below the coolant fill plug.
For other connections, see the attached pages. |
Wow: that is why this forum is so valuable.
http://www.jagrepair.com/images/Trai...ual-9-5-01.pdf :icon_dance-disco:
The first pic comes from the one LP provided... JagRepair.com - Jaguar Repair Information Resource
The 2nd is from a Jaguar parts site a few years ago, if I recall? ...I pulled it off my posted albums but the link was missing. The links courteously posted by MS are as Jim states,...valuable. |
Ok so this is what I'm piecing together right please let me know if any of this is correct...
This connector in front of the "octopus hose" goes to one of the hose coming off the EGR valve. The other hose off the EGR valve goes to the throttle body. https://cimg1.ibsrv.net/gimg/www.jag...6cceeddfb4.jpg This hard metal line which comes from under the pass side head goes to the throttle body???? https://cimg8.ibsrv.net/gimg/www.jag...bcdb941eba.jpg The hose at the top of the photo below goes to the small port coming off the intake elbow, the other hose off that t (the molded elbow goes to the bypass valve. https://cimg4.ibsrv.net/gimg/www.jag...a3a386cc2f.jpg But here is where I'm confused because the pdf posted above by M. Stojanovic tittle "Vacuum to EGR.pdf" shows another t connector underneath the EVAP canister with one line off it running to the T off the bypass valve, the other line going to I don't know. But my EVAP canister does not have this T connection, it just has a single line going to the T at the bypass valve. Also would still like to know where the larger port on the intake elbow goes. Thanks for the help so far everyone. |
And then I discovered this when I pulled the vaccum hose off the T that goes to the bypass valve and leads to the evap canister. In the sort piece of hose I pulled off the one that I think should go to the intake elbow there was a piece of another broken T connection, then I pulled the sort remainig pice off the little bit of hose that was left on the intake elbow, there is another piece of a broken T connector there too. I think these may be two pieces of the same T, if so, where does the other end of that T go?
https://cimg0.ibsrv.net/gimg/www.jag...58e3f52551.jpg https://cimg1.ibsrv.net/gimg/www.jag...fffa1abc8b.jpg |
Originally Posted by OUScooby
(Post 2097139)
(Post 2097139)
(Post 2097139)
(Post 2097139)
Originally Posted by M. Stojanovic
(Post 2097153)
The engine breather hose "T" should connect to the larger port on the LHS of the elbow, as shown in the file "Breather Hose.pdf" I posed earlier.
https://cimg8.ibsrv.net/gimg/www.jag...5688dfbebd.png
https://cimg9.ibsrv.net/gimg/www.jag...a84fb6d1ee.jpg OK so I found these two diagrams, the first one lays out pretty clearly how the hoses off the intake elbow go even though they don't really show where they go to, but it does confirm what I suspected about the small port on the intake elbow on the AJ27 engine, and a T coming off the small port on the intake elbow which leads to another T going to the bypass valve and evap canister. This is what I posted above in post #9 where I have the picture of the broken plastic T and the broken vacuum line. Now according to this 2nd diagram someone has labeled that T off the intake elbow as going to the MAP sensor, which I assume is somewhere on the air intake of the car? Can anyone confirm? |
(Post 2097640)
I've looked at that diagram in the pdf, but I don't know what the hose in the diagram corresponds to on my car in real life. Does anyone have a picture of this hose cause I'm still not sure what I'm supposed to be looking for.
https://cimg1.ibsrv.net/gimg/www.jag...2cfdcbd6b9.jpg https://cimg2.ibsrv.net/gimg/www.jag...5db4187677.jpg |
(Post 2097678)
The "breather" hose I mentioned is actually the PCV (Positive Crankcase Ventilation) hose. The first picture shows its connections to the LHS cam cover and to the the large port on the left side of the intake elbow. The second picture shows the connection of this hose to, I think, a Tee below the Purge Valve (sorry but I cannot remember exactly this connection at the Purge Valve and my picture does not show the connection very clearly but I think you will figure it out or your PCV hose might still be connected there).
https://cimg1.ibsrv.net/gimg/www.jag...2cfdcbd6b9.jpg https://cimg2.ibsrv.net/gimg/www.jag...5db4187677.jpg https://cimg5.ibsrv.net/gimg/www.jag...6b3a2765b6.jpg Also is this the T below the purge valve that is the other end of this hose? I assume a rubber hose goes off the part of the T pointing to the bottom of the picture, where does the other part of the T go? The one with the strange round connector? https://cimg5.ibsrv.net/gimg/www.jag...b4eb6f4591.jpg One final question the diagram I posted above in post #12 shows the other side of the intake elbow going to the brake servo. I found this line, which kinda sits the the vicinity of that side of the elbow and go all the way to the brake booster. Is this the hose that goes there and how does it secure into the intake elbow? https://cimg4.ibsrv.net/gimg/www.jag...e566e1ba1e.jpg https://cimg5.ibsrv.net/gimg/www.jag...3cf80ab319.jpg |
(Post 2098130)
(Post 2098130)
https://cimg4.ibsrv.net/gimg/www.jag...e566e1ba1e.jpg https://cimg5.ibsrv.net/gimg/www.jag...3cf80ab319.jpg https://cimg0.ibsrv.net/gimg/www.jag...5516d821f9.jpg |
(Post 2098187)
Yes, it is just pushed in. There should be a plastic collar (the black thing on the pic below) inside the hole you circled which comes a bit out when you try to pull the pipe out and grips it so the pipe cannot be disconnected. To disconnect the pipe, you need to hold the plastic collar pressed in, then the pipe can be pulled out. It is not clear from your picture whether the mentioned plastic collar is still in the circled hole. If not, you will need to buy p/n C2S15816:
OK so I received my new breather hose today and immediately I noticed something. The end of the hose that is covered by the silver heat shield is still on my car, it broke off at the T, but that means that this piece of broken hose I found when taking apart the car was not from this breather hose. So where did this hose come from? It is made of the same ribbed plastic material as the breather hose and has a rubber hose connection on the end, but this one is covered by a braided nylon hose protector. Am I missing another hose?
Here is the pic of the new hose, and the end of the old one still on the car: https://cimg7.ibsrv.net/gimg/www.jag...8f238f8fab.jpg https://cimg5.ibsrv.net/gimg/www.jag...b4eb6f4591.jpg And here is the broken pieces of hose next to the end of the new hose, notice how they don't match, on is just a piece of rubber hose as a connector, the other has the braided cable cover: https://cimg5.ibsrv.net/gimg/www.jag...9579c6549a.jpg Oh and one more question, my new breather hose came with a vacuum line under the silver heat shield, where does that go? |
(Post 2098187)
https://cimg0.ibsrv.net/gimg/www.jag...5516d821f9.jpg The one on my car now has lost that plastic piece so I can't look at that for reference. I'm going to try and but the new o-ring in the old one and hopefully that will save me having to swap out the whole brass piece entirely. |
(Post 2100441)
(Post 2100896)
Just out of curiosity, if I wanted to change the brass piece, how would I get the old one out and the new one in? I assume they press in?
