Need windshield wash pump pinout
Subscribe
Nov 8, 2016 | 10:42 AM
Hello all
I am trying to adapt a windshield washer bottle and pump from a 1998 XJ8 to my 1997 XJ6. The 1998 Jaguar washer bottle bolts into the car behind the front bumper just fine but the electrical connections are different. I have the electrical guide for my 1997 XJ6 car and the one for both a 1998 XJ8 and the 1999 XJ8 so I know the wire colors but I do not know which pin in the pump motor go to which. So there is a yellow with white wire, a yellow with green wire and a black wire arranged in a triangular pattern in the plug on the 1998 washer pump. Can anyone tell me which color wire connects to which pin in the pump wiring plug?
I will try to post a drawing or maybe a photo of the wiring plug on the motor later today if that would help.
Steve
Reply 0
Nov 8, 2016 | 03:02 PM
Are the bottles not the same where you can simply put the same year pump in the same year car? The picture idea is the best one and from what I read, it appears the wires may be out of the plug harness and that's the info you need to connect them up?
Reply 0
Nov 9, 2016 | 10:32 PM
OK, I was able to run by the shop this evening and snap these photos. Again I need to know which color wire connects to which terminal on the pump shown below. There are three pins. One is going to be a black ground, another is a yellow with white wire and then a yellow with green wire.
Reply 0
Nov 10, 2016 | 06:03 PM
Hope this helps....
Reply 0
Nov 11, 2016 | 07:15 AM
Doesn't help
No, unfortunately it does not. I already have all of that information. I need to see a photo of the actual wiring plug that goes into the pump or have someone tell me which wires got to which pin in the pump. I already have the wire colors from the 1998 wiring diagram. What I don't have is the info about which color of wire goes to which pin.
Reply 0
Nov 11, 2016 | 07:40 AM
Ok, I had to figure out why my bumper cover was loose anyways, so I went out and got this for ya.
Reply 1
Nov 11, 2016 | 11:29 AM
Quote: Ok, I had to figure out why my bumper cover was loose anyways, so I went out and got this for ya.
THANK YOU!!!!
Reply 0
Subscribe
Currently Active Users (1)
