new to this
own 97 xk8, low miles, love the car. a couple of issues. cig lighter does not work, need it to charge my phone, fuse indicator in the trunk says c14-20. pulled the interior panel where the fuses are and its graph shows it only goes up to c7, where is c14. i assume the amp (?) of the fuse is 20, correct?
2nd- speakers are shot and radio needs updating, took it to a local trusted audio place they want over $800 to replace all speakers and put in bluetooth audio streaming kit and fm antenna adapters so i can utilize my iPhone for my music, would you take it to a dealer? how do u get the valet off? |
lrg3isme,
If actually mean an XK, you would be better off to post in the XK Forum. Even if you have an XJ, not an XK, I would not suggest going to a dealer to do the audio upgrade you propose. Valet should be turned off if you've opened the car with the fob or using the regular key in the driver's door. |
Welcome to the forums. When you have time, please visit the new member area and introduce yourself:
https://www.jaguarforums.com/forum/n...-intro-must-5/ You can also cancel the valet function by using the black key to unlock the trunk. |
Originally Posted by lrg3isme
(Post 873473)
