Transmission application clutch and solenoid chart x308
I have a 1999 XJ8 x308 with the ZF5HP24 transmission, with which im having problems with.
To help diagnose this im searching for the ZF5HP24 APPLICATION CLUTCH AND SOLENOID CHART which shows which clutches and solenoids are used in which gears.Its usually a pdf file. I have one for the same gearbox in the XK8, but im not sure if its the same as it doesn't specify the file for the x308 Does anyone have this file information, if so I would greatly appreciate it. regards Peter |
It's the same transmission.
Go here- http://www.jagrepair.com/images/Auto...r%20Manual.pdf
You should be able to save it to your computer. Try here as well- https://www.mediafire.com/?d4qz5fksl4pi4 |
