Transmission application clutch and solenoid chart x308
Old Jul 29, 2014 | 07:29 AM
osyris's Avatar
Default Transmission application clutch and solenoid chart x308
I have a 1999 XJ8 x308 with the ZF5HP24 transmission, with which im having problems with.
To help diagnose this im searching for the ZF5HP24 APPLICATION CLUTCH AND SOLENOID CHART which shows which clutches and solenoids are used in which gears.Its usually a pdf file.
I have one for the same gearbox in the XK8, but im not sure if its the same as it doesn't specify the file for the x308
Does anyone have this file information, if so I would greatly appreciate it.
regards
Peter
Old Jul 29, 2014 | 08:24 AM
RJ237's Avatar
It's the same transmission.
Old Jul 29, 2014 | 11:19 AM
avt007's Avatar
Go here- http://www.jagrepair.com/images/Auto...r%20Manual.pdf
You should be able to save it to your computer.
Try here as well- https://www.mediafire.com/?d4qz5fksl4pi4
Forcedair1
Feb 19, 2020 01:51 PM
Will P
Sep 19, 2018 08:36 AM
tsimms7
Sep 15, 2015 12:43 PM
Phil G.
Sep 12, 2015 07:42 AM
1964Daimler
Sep 9, 2015 11:28 AM
