Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ8 / XJR ( X308 ) (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/)
-   -   What is the correct engine oil filter for a 2001 XJR? (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/what-correct-engine-oil-filter-2001-xjr-72347/)
smtguy Apr 28, 2012 10:04 AM
This might sound fairly basic, but I have heard a bit of discussion recently about oil filters and them not all being alike internally. I do think there must be some science here; and I tend to take a design/engineering approach to things so to begin with -
other than a Jag dealer purchased oil filter, what is a correct non factory replacement for my 2001 XJR?
Do different manufacturer's filters cause a difference in indicated engine oil pressure?
I always have purchased name brand filters, but is there a real difference, and can some filters lead to oil starvation or bearing damage?
Any technical insight from the membership is much appreciated.
vincent661983 Apr 28, 2012 11:01 AM
buy the genuine Jaguar filter on ebay
yeldogt Apr 28, 2012 11:46 AM
with the german cars - you can normally get the exact same Mann filter from one of the importers --with the Jag I normally get the OE -- you can get in wholesale online .... the interval is so long that I want the OE.
ixj8it Apr 28, 2012 01:01 PM
I use ac delco currently. Wix makes very good oil filters though. No cardboard construction like a fram or other brands. I change my oil every 3-4000 miles.
xjay8 Apr 29, 2012 07:49 AM
As they say Scot...there are filters and there are filters ;o]
Over the years Ihave come across some crap filters.
The list below is made up of filters I have used and trust.
They all have anti-drain back valves and pressure relief valves and have quality construction.
JAGUAR EAZ1354
BOSCH WO 133-1639479 ZX431991F
COOPER WC09
FORD XW4Z-6731-BA
FRAM PH 5618
HIFI HV5317
MANN W719/7
MOTORCRAFT FL2008
RYCO Z726
This list is based on what I can get in Australia plus a couple of overseas models.
I daresay there are others out there but like I said, there are filters and then there are crap ;o)
xjay8 Apr 29, 2012 07:51 AM
Have you got the numbers for the AC DELCO and WIX filters please.
Then I can see if they are available locally.
jimlombardi Apr 29, 2012 10:04 AM
Hi
I looked up 2001 XJR oil filters on the rockautoparts.com website:
AC DELCO Part # PF2254 (Alternate/OEM Part Number(s): 88997063) $7.52
WIX Part # 51228 {(Alternate/OEM Part Number(s): #PH5618} $10.18
BOSCH Premium Oil Filter Part # 72209 $3.66 (I paid $6.00 at local advance auto parts store) - no longer on their website - autopartswarehouse.com has it for $8.08.
Jim Lombardi
yeldogt Apr 29, 2012 11:10 AM
Wix - normally makes a fine filter.
I do not believe Bosch makes any filters - they are rebranded.
It would be interesting to see what the Ford/ Lincoln filter looks like - have not priced it.
The OE filter is quite large and heavy -- I paid $14.36 last year ... I think the drain plug may be close to that price! I believe the OE filter is a UK product - I don't have it in front of me.
Can't see the point in saving a max of $10 on this part.
jimlombardi Apr 29, 2012 03:29 PM
Hi
Jaguar Original Equipment Oil Filter part number is EAZ1354 and retail price is $17.95 discounted down to $13.65 on 2 Jaguar dealership websites.
And yes I agree with yeldogt on the small amount of savings between Jaguar dealership price and the after market oil filters. Too small price difference on something you only change occasionally.
But in my case, I did not want to order online and pay the shipping that amounts to more than the filter's cost. I also did not want to wait 4 to 10 days to get it.
Also the dealership is more than 25 miles each way.
Jim Lombardi
JaguarXJR02 Apr 29, 2012 08:12 PM
motorcraft FL-2021, I've been running them for the last 20,000 miles with no problems, $5 or so at walmart
xjay8 Apr 30, 2012 07:06 AM
Jim...thanks for those numbers....shall add them to my inventory ;o)
ixj8it Apr 30, 2012 08:31 PM
I thought walmart quit selling motorcraft filters.
JaguarXJR02 Apr 30, 2012 10:09 PM
I don't know, got one at my walmart about 3 weeks ago
plums Apr 30, 2012 10:49 PM
Crosland, usually available on ebay.co.uk
yeldogt May 1, 2012 04:51 PM
One thing to remember is that when you go to a Ford/ Lincoln dealer you get an OE part - The box will often be Blue -- it may or may not say Motorcraft ... most often not.
The motorcraft parts you buy outside of a Ford dealer are not the same parts -- those in the red/ white box.
My point -- A motorcraft filter from Walmart can and often are different than the filters in the blue box from Ford
Dan R May 3, 2012 09:30 AM
Mann filters usually get high marks in comparative reviews.
mechelement May 3, 2012 11:39 AM
Do you have proof of this? The boxes in WalMart are red and white with Motorcraft plastered all over them. If they came in a plain blue box w/o a name, how would the consumer know it's Motorcraft on the shelf in WalMart? Seems more like advertising or marketing for Ford. Ford needs to have parts in boxes at the dealership, but they don't need to advertise.
yeldogt May 3, 2012 01:19 PM
It is not a question of "proof" -- this is what it is.
Got to Ford Dealer get white box with blue lettering -- "Ford Genuine Parts"
Motorcraft is "recommended" by Ford -- go look at the Official Ford Parts website. They are not hiding anything.
Example: Spark plugs wires. The Blue Box will be the exact same as on the vehicle - perfect fitting lengths and ends specific to that vehicle - original quality. The Motorcraft will fit based on the engine family - and based on replacement quality to compete with other after-marketers.
Ford has always had an aftermarket devision that supplies all kind of parts.
mechelement May 3, 2012 02:12 PM
Understandable with plug wires, etc. I suppose they could do that with oil filters. I've run Motorcraft oil filters in my Powerstroke and they've been great.
yeldogt May 3, 2012 02:55 PM
...... used plug wires as an example -- because you can see the difference.
I have had the same with coils and relays. The brake pads and rotors are different.
The important thing is to understand that you can have a difference -- and the different price for an item may not be the color of the box - but the part inside.
I recently had this happen with a Nissan/ Infinity dealer -- they offered a very low price oil change ... When I asked ... How? They said they don't use the OE filter. I had no idea that Nissan would provide a "bulk" oil filter to the dealers that was different than a standard filter -- but they do and it is a lot lighter ... It must work ... but it is not the same? Black -- no "Nissan" to be found on it ... made in China :(
© 2026 MH Sub I, LLC dba Internet Brands
