wont start
Hello all , Ive got problem , I replaced the battery in my 95 xjr as the battery before woundnt hold a charge. Put the new one in now she wont start:(.......what gives ?? I read through the old threads and didnt see anything regarding batt replacement . Im guessing it has to do with the security system . Is there a re-learn protocol when the car is powered down ??? Any help would be great
Thanks |
RE: wont start
I replaced the battery in my 95 XJ6 and didn't have any problems.
RE: wont start
How do you mean..Won't start?
Does it crank at least? |
RE: wont start
It cranks and thats it.
When I tried to start it with the previous batt , it barely cranked and I noticed the gauges going crazy . Im pretty much a gear head but Jags are DIFFERENT from what im used too. Any ideas ? ( fuses to fuel pump , relays )) [sm=headbang.gif][sm=headbang.gif][sm=headbang.gif] |
RE: wont start
Ok , shot starting fluid in intake and car started , needless to say FUEL PUMP. Is this a pain to replace ??
RE: wont start
Fuel pump relay...fuel pump fuses?
RE: wont start
Yep checked all , power going to pump .
I'm going to assess the endevor of removing the tank tonight BUT may take it to a mechanic and have it done. |
RE: wont start
hose feed and return are released from the bottom... on top of diff.. pretty hard to do if you dont have a hoist.. there quick release.. but arent relly quick to release..lol
RE: wont start
Thanks for the info , I will give you update when finished [:-]
RE: wont start
Ok , wasnt the fuel pump .........I checked EVERYTHING 3 times over and I decided to buy a scan tool , turns out it was the Crank shaft position sensor !!! Burning rubber again !!
Thanks |
RE: wont start
Good job..and have fun![sm=gears.gif]
