wont start
Hello all , Ive got problem , I replaced the battery in my 95 xjr as the battery before woundnt hold a charge. Put the new one in now she wont start
.......what gives ?? I read through the old threads and didnt see anything regarding batt replacement . Im guessing it has to do with the security system . Is there a re-learn protocol when the car is powered down ??? Any help would be great
.......what gives ?? I read through the old threads and didnt see anything regarding batt replacement . Im guessing it has to do with the security system . Is there a re-learn protocol when the car is powered down ??? Any help would be great Thanks
It cranks and thats it.
When I tried to start it with the previous batt , it barely cranked and I noticed the gauges going crazy . Im pretty much a gear head but Jags are DIFFERENT from what im used too. Any ideas ? ( fuses to fuel pump , relays ))
[sm=headbang.gif][sm=headbang.gif][sm=headbang.gif]
Yep checked all , power going to pump .
I'm going to assess the endevor of removing the tank tonight BUT may take it to a mechanic and have it done.
Ok , wasnt the fuel pump .........I checked EVERYTHING 3 times over and I decided to buy a scan tool , turns out it was the Crank shaft position sensor !!! Burning rubber again !!
