wont start
Old Aug 2, 2008 | 07:28 PM
tbone's Avatar
Default wont start
Hello all , Ive got problem , I replaced the battery in my 95 xjr as the battery before woundnt hold a charge. Put the new one in now she wont start.......what gives ?? I read through the old threads and didnt see anything regarding batt replacement . Im guessing it has to do with the security system . Is there a re-learn protocol when the car is powered down ??? Any help would be great
Old Aug 2, 2008 | 08:59 PM
badmojo's Avatar
Default RE: wont start
I replaced the battery in my 95 XJ6 and didn't have any problems.
Old Aug 2, 2008 | 09:42 PM
Dennis's Avatar
ud
How do you mean..Won't start?
Does it crank at least?
Old Aug 3, 2008 | 08:07 AM
tbone's Avatar
It cranks and thats it.
When I tried to start it with the previous batt , it barely cranked and I noticed the gauges going crazy . Im pretty much a gear head but Jags are DIFFERENT from what im used too. Any ideas ? ( fuses to fuel pump , relays ))
[sm=headbang.gif][sm=headbang.gif][sm=headbang.gif]
Old Aug 3, 2008 | 02:18 PM
tbone's Avatar
Ok , shot starting fluid in intake and car started , needless to say FUEL PUMP. Is this a pain to replace ??
Old Aug 3, 2008 | 09:03 PM
hlgeorge's Avatar
Fuel pump relay...fuel pump fuses?
Old Aug 4, 2008 | 11:07 AM
tbone's Avatar
Yep checked all , power going to pump .
I'm going to assess the endevor of removing the tank tonight BUT may take it to a mechanic and have it done.
Old Aug 5, 2008 | 06:06 PM
jag_genius's Avatar
hose feed and return are released from the bottom... on top of diff.. pretty hard to do if you dont have a hoist.. there quick release.. but arent relly quick to release..lol
Old Aug 5, 2008 | 08:40 PM
tbone's Avatar
Thanks for the info , I will give you update when finished [:-]
Old Aug 17, 2008 | 08:10 PM
tbone's Avatar
Ok , wasnt the fuel pump .........I checked EVERYTHING 3 times over and I decided to buy a scan tool , turns out it was the Crank shaft position sensor !!! Burning rubber again !!
Old Aug 17, 2008 | 10:32 PM
Dennis's Avatar
ud
Good job..and have fun![sm=gears.gif]
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
