XJR-R1 Brake Squeal
I got potentially bad news yesterday from Buckhead Imports and Butler Tire. They told me that there is no cure for my loud brakes.
What pads are quiet on the 355mm Brembo brakes? |
Originally Posted by squish
(Post 321200)
What pads are quiet on the 355mm Brembo brakes? I'm using Pagid |
(Post 321200)
What pads are quiet on the 355mm Brembo brakes? Funny thing is the Alcon's I use now are fitted to the XKR-S and they use the same Ferodo's, something in that fact. |
what do you guys think of the Hawk Performance Ceramic Pads
Can only remember some brake squeel (for short periods) with the Hawk Ceramic pads I use (4th set is going on soon). But I also had it with Pagids before. It is in the combination of the pad & rotor, so new pads or sanding yours a little, new break-in could already help, but it might be temporary.
(Post 321200)
I eventually got EBC Yellows for each corner. They helped a ton. There is still a little squeak every now and again, but nothing like the howl that used to come from the rears (Mintex).
ViaPA, I'll be looking for you. Actually I've been hunting you down to buy your old exhaust system...! |
