hub carrier pivot pin spacer
hi guys,
does anyone know how you decide on the size of a new pivot pin spacer to replace the one taken out, as this one is damaged.. Sizes seem to go from3.905 to a range of about 8 sizes. car is 1992 xj40 sov. regards signalred |
signalred,
I've moved your question from XK120 XK140 XK150 (1948-1962) to XJ40 (1986-1994) forum. Members here with the same model will be able to help. Graham |
even when damaged, you should be able to use a micrometer or digital calipers in the remains to determine its thickness
