Ignition Key Barrel
I've looked through the archives and found many posts
regarding the key(lock) barrels for the doors, but my inquiry is directed to the ignition barrel, and I found no posts which answer my question. (I could have missed it too) A few years ago I purchased new door handles which came with new barrels and keys to fit. Thus leaving me in the position of having a key for the ignition and a different key for the doors (and another key for the boot). The key for the ignition has worn down significantly and is very loose in the barrel. I'm concerned at some point in time the key won't properly work the barrel pins and most likely it will be at a very inconvenient time. I want to know if it is possible to ''retool'' the ignition barrel to fit a newer key. Is the ignition barrel like the door lock barrels, so a different key can be fitted to it? I looked up the price of a new ignition key barrel and .....I cried...... :) (not really, but they are expensive) Thanks in advance for any input. |
Originally Posted by Rob Evenson
(Post 664805)
regarding the key(lock) barrels for the doors, but my inquiry is directed to the ignition barrel, and I found no posts which answer my question. (I could have missed it too) A few years ago I purchased new door handles which came with new barrels and keys to fit. Thus leaving me in the position of having a key for the ignition and a different key for the doors (and another key for the boot). The key for the ignition has worn down significantly and is very loose in the barrel. I'm concerned at some point in time the key won't properly work the barrel pins and most likely it will be at a very inconvenient time. I want to know if it is possible to ''retool'' the ignition barrel to fit a newer key. Is the ignition barrel like the door lock barrels, so a different key can be fitted to it? I looked up the price of a new ignition key barrel and .....I cried...... :) (not really, but they are expensive) Thanks in advance for any input. I'm not sure about the ignition lock but interestingly enough just last Friday I was having lunch with a pal who has a 2004? XKR and we compared ignition keys - the key was identical to my 94' XJ40 so we guessed there may be something in the handle that differentiates the keys from one another? Looking at my valet key, I can't see any difference in the pattern but obviously there is a difference as the valet key won't open the trunk. Larry |
As I recall, the inside parts can be moved around to match any key. There are just a bunch of washer shaped pieces inside which are turned to match the key you have. You just have to put them in the right order. And that probably takes someone who knows how to do it.
I swapped the ignition cylinder from my parts car to my daily driver. If you don't know how, see this: 1990 Jaguar Sovereign : Remove Ignition Key Cylinder | AndyRupert.com |
Hi Andy,
Thanks for the input, I have a better idea of what to look for. I'm amazed at the lack of response on the subject! Either I'm a complete idiot for asking the question, or, close to no one has performed this task. (re-keying the ignition cylinder). Based on your blog article, it sounds like you swapped the cylinder, but did not actually re-key the cylinder, is this correct? I've found a number of vids on youtube which demonstrate the task and some posts from a variety of non-jag forums with photos. I'm going to assume the principle is the same. One post with high detail pics was for either a VW or a Porsche 944. Guess I'll just have to venture on this one alone..... Thanks again.
Originally Posted by andyrupert-com
(Post 666331)
(Post 666564)
Hi Andy,
Thanks for the input, I have a better idea of what to look for. I'm amazed at the lack of response on the subject! Either I'm a complete idiot for asking the question, or, close to no one has performed this task. (re-keying the ignition cylinder). Based on your blog article, it sounds like you swapped the cylinder, but did not actually re-key the cylinder, is this correct? I've found a number of vids on youtube which demonstrate the task and some posts from a variety of non-jag forums with photos. I'm going to assume the principle is the same. One post with high detail pics was for either a VW or a Porsche 944. Guess I'll just have to venture on this one alone..... Thanks again. To my knowledge, it's not possible to get an ignition cylinder from the '88-'89 XJ6 apart, such that it could be put back together and re-used. Back in the day, for my good clients that had to have a new ignition barrel, I would offer to use the new ignition key and open up the door handle cylinders and re-code them to match it. The door cylinders can be removed and the tumblers replaced or rearranged to code the doors to the new [or newer] ignition key. I kept every lock cylinder from all the door handles I ever replaced so I had a good supply of tumblers on hand. My suggestion would be to try and find a better ignition cylinder and try that. If you do and find you need tumblers, holler and I'll try to help fix you up. Might even be able to dig up a viable ignition barrel. Hope that helps! |
Steve,
Thanks for the additional information. It appears '89 was the last year before the style of key was changed. I would need components from a model with a VIN up to 594575. Beyond that number, it's a newer key style. I've contacted a few ebay sellers to see if they have the key with the wrecker they're parting out, will have to wait and see what they find. I may take you up on the offer for the "waffers/tumblers" if I can find a good assembly. I can't stand the thought of spending $230 to $290 for a new lock cylinder. Thanks again |
8 Attachment(s)
(Post 667321)
Steve,
Thanks for the additional information. It appears '89 was the last year before the style of key was changed. I would need components from a model with a VIN up to 594575. Beyond that number, it's a newer key style. I've contacted a few ebay sellers to see if they have the key with the wrecker they're parting out, will have to wait and see what they find. I may take you up on the offer for the "waffers/tumblers" if I can find a good assembly. I can't stand the thought of spending $230 to $290 for a new lock cylinder. Thanks again Here are some pics of the ignition barrel from an early XJ40. The shell around the key side of the barrel is extremely hard, and therefore brittle. I had a locksmith try a couple, years ago; those tabs look like they should flex outward and release the cap, but it turns out any attempt to flex them, just breaks them, because they are so hard. That's why I just resorted to re-keying the doors to match a new ignition key. Much easier that way. Hope that helps! |
Steve,
Super cool on the follow-up on your part, thanks so much!!! I'll put this to rest in my mind. Thanks again. |
xj40 ignition barrell
hi guys, does anyone know how to replace a new ignition barrel in a 1992 xj40, step by step if possible
kind regards signalred. |
