XJ40 ( XJ81 ) 1986 - 1994
Need a Used-ABS Pressure Monitor SWitch
Old Sep 23, 2008 | 12:49 PM
Frankie's Avatar
Default Need a Used-ABS Pressure Monitor SWitch
Looking to purchase this for my 1988 XJ40. Located on the lower part of the brake valve block..right side , lower front.
Frankie
Old Sep 24, 2008 | 03:48 PM
ken@britishparts.com's Avatar
Default RE: Need a Used-ABS Pressure Monitor SWitch
Do you need the low pressure switch or the charging switch? If you aren't sure, get the numbers off the side. It's a long number that begins with "7."
toronadomike
Jan 22, 2026 10:13 PM
Rivguy
Nov 13, 2022 02:55 AM
Aus V8S
Nov 13, 2015 11:01 AM
fingers
Sep 11, 2015 12:21 PM
tonyforman
Sep 10, 2015 07:23 PM
