Replacing Sovereign Door Panels with VDP Panels
Hi: I believe the VDP front door speaker size is 5.25" vs the 4" on my Sovereign. I am thinking of swapping them to gain more front sound. I have a few questions:
1) Were the mounting clips spaced the same for 88-94? 2) Are the electrical connectors compatible? Thanks, Ren |
Not sure about the clip locations, but would plan on them being same, however I would be very surprised if any electric connectors match. Even the mirror and window switch plugs are different 92-94
Originally Posted by jerry_hoback
(Post 2050964)
I'll get to it one of these days I guess :icon_tinykitball: Larry |
Ren,
Aside from the possible electrical connector differences, the holes in the door metal to receive the door casing/interior trim panel/door card fasteners should all be in the same places, and if not you could always drill new holes if necessary. The female nylon "cowboy hat" fasteners and male "fir tree" fasteners tend to wear out and/or break when you pull them apart, so you may want to have some extras on hand before you do the swap. Cheers, Don |
