Trunk battery cover turnbuckle female receivers, part number or dimensions?
2 Attachment(s)
Both of the female battery cover turnbuckle receivers in my XJ12 are missing.
Jaguar has used a number of these throughout their vehicles for years to hold various panels in place, and some are metal, some are plastic, and they can vary in size. Does anyone know the part number or dimensions for the female receiver used in the XJ40 battery cover? Here is the trunk linings diagram and part listings for the XJ40, but it doesn't call out the turnbuckle receiver, even in the "unillustrated parts" listing. https://www.jaguarclassicparts.com/u...and-insulation The XJS parts diagram does show a similar (the same?) turnbuckle receiver, and is item 5 in the diagram below: https://www.jaguarclassicparts.com/u...re-wheel-cover |
1 Attachment(s)
Here's a photo that highlights where the two turnbuckle stud receivers clip into, note the two empty rectangular holes in the black metal bracket:
Hi Al,
I thought part 14 in this diagram might be the turnbuckle receptical clip you're looking for but the description says it's the "battery positive terminal post cover": https://cimg1.ibsrv.net/gimg/www.jag...9a484a8664.png I found this in the Battery/Starter/Alternator section: https://www.jaguarclassicparts.com/u...ry-and-fixings Part number was DBC12286 which was superseded to XR811245. You'd have to think that dealerships had to replace those clips from time to time so there must be a part number! Cheers, Don |
I'm not sure about this, but do the footwell fuse box covers use similar stud receivers?
Larry |
Originally Posted by Lawrence
(Post 1915189)
Larry Not sure, but will go look and let you know. Jaguar used several different sizes and materials (plastic and steel) versions of these receivers throughout the car and across models. . |
