1983 XJ6 blinker problem
Hi all - new here.
The blinkers on my 1983 XJ6 will work correctly until I take it to get inspected. By the time I get to the station, they won't come on. I can let it set for a week or two and start it up and they work fine. Does this sound like a relay? Thanks! |
Just a wild guess, but, I'd suspect the flasher. Swap in a new one.
Carl |
If all the blinkers simultaneously work and then don't work, I agree with Carl. A dud flasher is a very likely suspect.
If it's more of a case where some work, and some don't....it might be something else. As with all electrical problems checking and cleaning all relevant electrical connections before replacing parts is a good practice. For example, you might pull the flasher and examine the pins and sockets for corrosion. Cheers DD |
Thanks! Back in my day, when the flasher went out the lights just stayed on. Here, I don't get anything. I'll swap it out and try it.
Thanks! I'll check those too before changing parts.
sounds like low blinker fluid to me :)
do the Emergency Flashers work? (Hazard Warning), or do you also get nothing?
Don't think that's it...just added a quart of Crown Royal to it. Should work fine!
Don't think it's that...just added a quart of Crown Royal. Should work fine!
I don't get anything. The hazard flashers also stay off.
