1986 Series III V12 transmission oil cooler?
Was a transmission oil cooler factory installed on a 1986 Series III V12?
If not, is it a good idea to fit one? |
All auto transmissions have a method to cool the fluid. Just get under and you should see two lines.
As to a supplemental, views differ. Carl |
Originally Posted by Dutch-Cat
(Post 1597395)
It is incorporated in the engine cooling radiator If not, is it a good idea to fit one? Yes....if you have some reason to believe the existing cooler isn't enough for your driving habits or conditions. Cheers DD |
