Connector
connector off the right hand (drivers) side of the series 3 radiator, what's it for and where go too?
also I can see the temperature sender nub on the engine but it has no spade or connector? should i purchase and after market replacement or can I attach a 'spade link' or such to it and where/what is the cable that should attach to it. https://cimg8.ibsrv.net/gimg/www.jag...6308b42217.jpg |
Originally Posted by adenshillito
(Post 1399905)
Offhand I'd say that's the connector to the radiator-mounted thermo switch that controls the electric fan also I can see the temperature sender nub on the engine but it has no spade or connector? should i purchase and after market replacement or can I attach a 'spade link' or such to it and where/what is the cable that should attach to it. I'm not sure if I understand the question. But, the wire for the temp sender is usually green Cheers DD |
I can see the temperature sender thing on the engine but it doesn't have a connector on it to attach a wire too .. does that make sense?
Who do the TWO PINS on the radiator's temperature plug as pictured above work?
