Front left hard brake line C.42137
Old Jun 6, 2020 | 08:40 AM
yachtmanbuttson's Avatar
Default Front left hard brake line C.42137
When doing my exhaust manifold project, I spotted a brake fluid leak in my front left hard line that goes from the proportioner valve manifold to the front right brake flex line. Tightening it did no good; only made it worse. It's a fairly new flex line. Does anyone have a C.42137 small brake line I can acquire? See below pic:
Thank you, Bill
File Type: pdf
Old Jun 6, 2020 | 01:29 PM
JagCad's Avatar
David Boger everyday xj!!!
Off to play in the shop.today, move jaguar. Make sawdust...
Carl
Old Jun 6, 2020 | 02:44 PM
Thanks. I've asked; he's looking.
Old Jun 7, 2020 | 09:19 AM
My Mercedes mechanic says he can make up any brake line. I'm bringing it to him tomorrow to see.
Old Jun 7, 2020 | 12:29 PM
JagCad's Avatar
Oh, ?// I could not make it out in the first picture. The second clarifies immensely. You said flex line in the post. The second picture is a hard line. Unless the fittings are some odd shae, the NAPA sh sells them in various lengths, made up.
Or just use the old fittings on a new line. I doubt that will work. The fitting is the issue. Worn seat or bore.
HF sells a decent tool to flare brake tubes. The better one, required here, does the double flare...
I hope all is well and the Benz tech makes up one that does not leak...
Carl
Mongoose
25
Aug 16, 2021 12:04 AM
Brewster411
May 15, 2020 08:33 AM
bwbowers
Apr 27, 2020 06:13 PM
TN8Shooter
Jun 11, 2011 09:51 AM
