headlight spacing
On a '86'ish XJ6 with the quad headlamps ...
what would be the horizontal spacing of the beams the easiest way to measure this would be from an edge of the trim ring to the same edge of the trim ring on the neighbour and the front to back offset between inner and outer globes easiest would be the difference in the sections of the mounting plate in the back. I have seen a picture of a set, and the reason for my curiosity is that I think they would be a good way to mount H4 conversions on a X308. |
Originally Posted by plums
(Post 1271006)
what would be the horizontal spacing of the beams the easiest way to measure this would be from an edge of the trim ring to the same edge of the trim ring on the neighbour and the front to back offset between inner and outer globes easiest would be the difference in the sections of the mounting plate in the back. I have seen a picture of a set, and the reason for my curiosity is that I think they would be a good way to mount H4 conversions on a X308. On the series XJs the headlamps are individually mounted, the inner ones are mounted to the bonnet/ hood the outers are mounted on to the wing/ fender. The mounting buckets have no provision for auto adjustment either. |
That was the guy's best guess as to year and model.
I'll take a closer look. It's definitely a quad 5.75 inch setup. |
