headlight spacing
Old Jul 20, 2015 | 10:52 PM
plums's Avatar
Default headlight spacing
On a '86'ish XJ6 with the quad headlamps ...
what would be the horizontal spacing of the beams
the easiest way to measure this would be from an edge of
the trim ring to the same edge of the trim ring on the neighbour
and the front to back offset between inner and outer globes
easiest would be the difference in the sections of the mounting
plate in the back.
I have seen a picture of a set, and the reason for my curiosity
is that I think they would be a good way to mount H4 conversions
on a X308.
Old Jul 22, 2015 | 04:06 AM
andrew lowe's Avatar
plate in the back.
on a X308.
On the series XJs the headlamps are individually mounted, the inner ones are mounted to the bonnet/ hood the outers are mounted on to the wing/ fender.
The mounting buckets have no provision for auto adjustment either.
Old Jul 22, 2015 | 04:51 AM
plums's Avatar
That was the guy's best guess as to year and model.
I'll take a closer look.
It's definitely a quad 5.75 inch setup.
Poet
Feb 7, 2025 02:18 PM
hoodun
Nov 20, 2022 02:35 PM
bdboyle
Nov 6, 2015 02:07 PM
Delta66
Oct 4, 2015 05:40 PM
kevinl
Sep 24, 2015 08:25 PM
