Series One dashboard - loose
Hi all:
The center dash panel on my '71 is loose. This is the panel with all the center gauges and rocker switches. The panel rides on two pins at the top and they are not really securing it in place. How is this panel properly secured/tightened? Thanks. Dave |
1 Attachment(s)
I just do up the black screws at the top corners, I have put small rubber gromets on the screws . I have no hinges at the bottom as a PO removed them for some reason.
No rattles, just done up finger tight. Attachment 105733 |
It is supposed to hinge down on the bottom pins
2 Attachment(s)
Without the bottom pins installed, you can remove the two screws and pull the door outward and tilt it down.
With the additional stuff in the center parcel tray... it would not hinge downward without removing the "stuff". I chose not to remove the bottom pins but to take out the dual AC vents if the fuse panel needed to be lowered. Same choice was made on both S1 cars... did not want the associated rattles... If you are missing the ability to hinge yours downward, let me know - I have spare parts. |
Originally Posted by Roger Mabry
(Post 1155131)
Air con unit prevents fuse door from tilting
Yes, you have the same "condition"... a small price to pay for added air flow.
(Post 1155262)
So, the panel is actually intended to flip forward?
Originally Posted by ChampInSD
(Post 1156184)
1 Attachment(s)
I see. Well, I looked at it more carefully today. The problem is here:
There must have been some sort of plastic disc/grommet on these, which have broken away. Does this pin separate? I tried to unscrew its but no joy. Either way too tight or not two parts I guess.
2 Attachment(s)
If you have a look at my picture in #2 of this thread you will see the two plastic knobs pointed to with red arrows. Those plastic knobs are molded onto the knurled part of the screws in your picture
Update, here is what they should look like. Try David at everyday XJ, he should be able to sort out a pair for you.(he is a member of the forums.) https://www.jaguarforums.com/forum/x...yday-xj-91303/ Attachment 105941Attachment 105942 |
Thanks. That would make a lot of difference.
Bottom pivot point(s)
1 Attachment(s)
This is what the LH pivot point looks like...on the inside.
Knob above the ignition switch is the Hella intermittent wiper switch. |
(Post 1157214)
Knob above the ignition switch is the Hella intermittent wiper switch. Going by your pic I have all I need between my two switch panels to make everything work properly. |
