SIII fuel tank into SI fittings source?
3 Attachment(s)
Anyone know where to get fittings for series III tank fuel line? I am putting one in drivers side of my 73 series I and would like to use the original metal fuel line instead of the fatter SIII hose, as it's going to the mechanical fuel pump.
Just went to Napa Autoparts but no joy there. |
Hope you have the later filler caps to go with the new S3 tanks?
Originally Posted by Roger Mabry
(Post 1831832)
Is what you are showing what you need? That looks like the fittings out of the Series 3 tank.. One that is the larger supply line and the other return that goes across the muffler... I have those I think.. Or are you looking for something else..
(Email me if you want - EverydayXJ).. David |
Originally Posted by davidboger
(Post 1831845)
(Email me if you want - EverydayXJ).. David //That XJC door was perfect btw, thanks for that! |
I'm confused, you are asking for the fittings but you have them already? Or is this someone else's images?
A salvage yard/breaker is probably your best best. You will likely have to talk to someone because its a random part that wouldn't be listed online. |
Originally Posted by sidescrollin
(Post 1832273)
A salvage yard/breaker is probably your best best. You will likely have to talk to someone because its a random part that wouldn't be listed online. The longer metal fitting is what was threaded into my original SI tank, which I have removed due to rust and holes. what I need is something that will screw into the series III tank but allow for the thinner metal fuel line which goes to the fuel pumps under the boot/trunk floor. Somewhere out there is a threaded male connector/adapter that will allow this, and it won't be an original part ... |
What you are searching for is a flare reducer bushing. Try searching Parker Hannifin fittings on line catalog. Another good source is McMastercarr.com> you may have to use a couple of fittings to get to where you need to be. You could also stop by the local hydraulic shop that makes hoses they may have adapters.
Originally Posted by avern1
(Post 1832331)
Cheers |
I would advise to get back to original condition. The electronic SU fuel pumps are around $250 each. The original wiring just switches between pumps. The valves in the pumps stop tranfer between tanks. I still have my original tanks after 48 years, new pumps and lines from tanks to pump. That is all. Am sending you a pm.
https://cimg0.ibsrv.net/gimg/www.jag...30441a2677.jpg |
Somehow the above post was placed on the wrong thread - apologies.
if your project is done do You still have some of those fittings left ?
