Spectra Fuel Tank - Series III
Hi All!
I know there have been some questions as to the build quality of Spectra fuel tanks for our cars. I decided to take the chance after my right-hand tank completely failed and QuickSteel putty failed to provide a long-term solution. I'm proud to say that the Canadian manufactured tank is a stellar replacement for the factory Jag unit. The seams are identical, the material is actually a little more robust, and all mounting/connection points are perfectly placed. The new tank even came with a new o-ring for the filler neck and a new gasket and lock ring for the float/sender unit. For $315USD, I consider it a great value. The only thing it lacks over the factory unit is the chunk of sound absorbing material on the outside. Anyone needing a new tank, I can't recommend these highly enough! |
Nice to hear. The factory is just down the street from where I worked prior to retirement. They used my old Corvette as a test buggy for a new line of tanks they were bringing out. Top quality stuff from what I saw.
Originally Posted by Mikey
(Post 927206)
