wiring diagram daimer double six (XJ12)
Hello,
I am having problems finding a good wiring diagram for this car build in 1979 (series III). I 've tried the diagrams on www.jagforums.com and on www.jaguar-online-club.de but The quality is so bad that I hardly read nor print the wiring colour code. Does any one has a solution? m. thanks |
addendum
Originally Posted by patpin
(Post 1059191)
Hello,
I am having problems finding a good wiring diagram for this car build in 1979 (series III). I 've tried the diagrams on www.jagforums.com and on www.jaguar-online-club.de but The quality is so bad that I hardly read nor print the wiring colour code. Does any one has a solution? m. thanks “Lucas 2PA Power injection power amplifier”, not controlled by the ECU. |
That 2PA sounds like the injector driver amp, big silver box up on the radiator support panel from memory.
I reckon I got something, somewhere in my thousands of scribbling in the shed. I will look after work, and scan and attach here for you. |
1 Attachment(s)
Originally Posted by Grant Francis
(Post 1059510)
You have send me a big part of the diagram. Unfortunately it is starting with column M and there is no list of devices. Is it possible to send them to me? Many thanks!! |
OH.
Its on a fold out page and way too big for my copier/scanner as a whole. I will look at work when I go tomorrow, and see if I can sort it, but by shrinking it to fit will lose the detail, dunno, "IT" is not my area. |
3 Attachment(s)
OK, the 9 cylinder V12 I was sorting is all sorted, and it took less time than I planned, simple engines for us simple people.
I found another book that I am not that attached to, so seperated the related pages, INCLUDING an index, and here they are. If its not what you need, I have exhausted my supply. The D Jetronic is a simple analogue system, and is quite reliable as compared to the later system/s. Attachment 95996 Attachment 95997 Attachment 95998 |
many thanks Francis , i 'll look at it soon. I have to repair the alternator first. Keep well.
