wiring diagram daimer double six (XJ12)
Hello,
I am having problems finding a good wiring diagram for this car build in 1979 (series III).
I 've tried the diagrams on www.jagforums.com and on www.jaguar-online-club.de but The quality is so bad that I hardly read nor print the wiring colour code.
Does any one has a solution?
m. thanks
m. thanks
Hello,
m. thanks
m. thanks
“Lucas 2PA Power injection power amplifier”, not controlled by the ECU.
That 2PA sounds like the injector driver amp, big silver box up on the radiator support panel from memory.
I reckon I got something, somewhere in my thousands of scribbling in the shed. I will look after work, and scan and attach here for you.
You have send me a big part of the diagram. Unfortunately it is starting with column M and there is no list of devices. Is it possible to send them to me? Many thanks!!
OH.
Its on a fold out page and way too big for my copier/scanner as a whole.
I will look at work when I go tomorrow, and see if I can sort it, but by shrinking it to fit will lose the detail, dunno, "IT" is not my area.
OK, the 9 cylinder V12 I was sorting is all sorted, and it took less time than I planned, simple engines for us simple people.
I found another book that I am not that attached to, so seperated the related pages, INCLUDING an index, and here they are.
If its not what you need, I have exhausted my supply.
The D Jetronic is a simple analogue system, and is quite reliable as compared to the later system/s.
D Jetronic wiring diag 1.pdf
D Jetronic wiring 2.pdf
D Jetronic wiring legend.pdf
Daniel Howden
Sep 13, 2015 02:28 PM
