1989 5.3 V12 power steering fluid leak
I guys i have 89 xjs 5.3 v12, the power steering fluid is leaking as soon as i put it in 5 mins later its all leaked out. How hard is it to fix this leak as im not very mechanical.
You need to identify where the leak is coming from; is it the rack itself, the hoses/connections or the cooler?
dont forget the pump
put a large bit af flat cardboard under the car, and turn over the engine, if its leaking that much i would turn it of right away , look at the cardboard and it will give you a clue to where the leak is the hoses are prone to wear and or cuts, the unions can go but are more robust, the pump seal can go , but as above , you need to identify the leak first on the V12 there is a cooler mounted on the front subframe on the left of the engine bay b the engine mount, they can rot out to , BB |
My pipe and rack were peeing out oil. I resealed the pump and will be doing the rack this weekend. Then it should be better than new.
